Gas sensor gauge reading faulty on 2000-2005 Cadillac DeVille?
do I need the full fuel sender with pump?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi, If your fuel sensor is bad you will need a new fuel pump as the sensor is part of the pump assembly. I am including a link to a forum discussion on the matter with a possible solution to the pump reading problem and if you go all the way down a possible easy access to the pump assembly. Good luck Ralph
このアンサーは役に立ちましたか?
++ nice link
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 10,084
