Do I remove the protective cover removed?
In step 37 B you show that you are raising the red protective cover from the display. Is this required? I am repairing an IPhone 4 CDMA and the red cover is still on there. Please help soon.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, remove the protective cover on the back of the new LCD assembly.
WARNING: Failure to remove the protective cover from the mirrored back of the display assembly will damage the LCD. There is a thermal pad installed on the iPhone frame that absorbs the heat from the LCD and disperses it though the frame, preventing the LCD from
overheating.
このアンサーは役に立ちましたか?
Thank you for the helpful info. I have now replaced two front displays and removed the transparent protective cover.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 76
