メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
締切られた回答
Screen went black, took it apart and battery started to smoke.
I was using my phone and everything was working fine. I then went back to use my phone about an hour later and the screen looked like it was trying to start up, like it was first booting up but without the apple logo. I then attempted to take it apart to take the battery out however when I did start to lift the battery out it began to smoke. The phone was on because we could not turn it off. When it began to smoke I put the phone back together and tried to charge it, It vibrated as if it was taking a charge but the phone didn't turn on, I left it there for about an hour and when I came back it was very hot and I unplugged it. Any suggestions? Is my phone toast or would a new battery do the trick?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You need to be very careful with any lithium type batteries. They can catch fire and are self oxidising so you will have trouble trying to extinguishing them.
You should have disconnected the battery first from the iphone circuit board before trying to remove it.
It sounds like your battery is definately toast now so you've got nothing to lose by trying a new one. Just be careful.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 378
