Display Is Line When Boot Up
When I Boot Up My Macbook Air 2012
Is Show One Vertical Line Between LCD...
What The Solution For This Problem?
This is a common issue among Macbook Airs. Reset your PRAM by holding down Command-Option-R-P until you hear a second chime.
このアンサーは役に立ちましたか?
Already Reset PRAM But Still Same...
このアンサーは役に立ちましたか?
Could you post a picture? This sounds like the LCD/LCD cable is damaged.
This Is My Problem..
このアンサーは役に立ちましたか?
It appears to be a bad LCD screen, what is the screen size of your model?
13 Inch LCD Display
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 102
