iPhone searching after replacing my battery, whats the problem
my iphone brings searching after replacing my battery, whats the problem, how can i solve it? i'm nervous
Try Airplane mode ON and then off, if it dont help try this-press home and sleep/wake button together till you see apple logo, then let go. Worked for me.
このアンサーは役に立ちましたか?
Check your date and time settings, often after a battery replacement the date and time settings can become skewed, causing this issue. Make sure to set them to set automatically.
このアンサーは役に立ちましたか?
Connect to wifi and wait until the phone picks up the correct time and date, then select airpane mode on and then off, your network signal should then reappear.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 75
