メインコンテンツにスキップ
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
38の回答 すべてを表示
How to take nook hd out of demo mode?
Yes, I bought the demo model. Which I thought was a heck.of a deal! Now, its a HEADACHE! I have not done a factory reset as I've read in other forums I will have to register with the same information as is existing. Since I don't know for sure I'm skeptical to perform this step. I've found the secret menu and un√ "demo". Ive then turned it off & restarted but this does not work! It goes right back to demo mode.
Since I was never able to erase/deregister, any other suggestions? Has anyone done a factory reset? Will I need to know the previous info? I have a file explorer app. Is there a program I can delete so it will stop looping and turn off? It never shuts off til the battery is drained.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Ok , I jumped the gun . I figured it out. I bit the bullet & did a hard reset to factory & it worked. Hope this will help someone in the future . Don't forget to backup ur stuff b4 doing or its gone!
この回答は役に立ちましたか?
スコア 2
コメント:
Glad you tried the reset. I would have said to do a factory reset too. There is no registration required for a reset as you have already figured out. It just erases any apps, pictures, videos, documents and anything else a person has saved on the device that is not included with the stock Rom. Good job.
さんによる
コメントを追加
回答を追加する
Hello さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 851
