Why won't my iPAQ turn on?
My iPAQ won't turn on. It needs to stay plugged in to work and when i disconnect the charger, it powers off.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The issue you're experiencing is very likely related to the battery. The battery replacement process is fairly simple to do yourself. Here is a guide that will help you out!
このアンサーは役に立ちましたか?
I have another question then - should iPaq work without the battery connected? Mine doesn't and I'am trying to figure out whether it's a battery only or a battery + cable/port issue
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 360
