M-Audio keystation Mini 32
I have no sound from keyboard in garageband.
In my old computer (OS10.7.4) it works fine. Do you know why it doesn't work in OS 10.10.3 ?
Hello!
It's seems to be a problem with USB 3 according to this discussion:
https://discussions.apple.com/thread/676...
Not enough power from USB 3. Try to use a USB 2 hub between the computer and the keyboard.
Best Henrik
このアンサーは役に立ちましたか?
It appears that this keyboard is not compatible with USB 3.0. Find a USB 2.0 cable, one without the blue connectors on the end and use that. It should make your system default to the old 2.0 protocol in which case your keyboard will work fine.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,285
