Is there a guide for changing batteries?
Is there a guide for changing batteries? I cannot find a guide for removing/replacing batteries. I need to change mine and need som help.
Iacob
This battery is really simple to change.. The problem is that that battery may Crash and be really danger for technician. I suggest to cover with any piece of strong metal. Apple give a special protection to remove this battery.
このアンサーは役に立ちましたか?
i don't understand what this answer means...what does it mean for the battery to crash? what is the danger to the tech? and what should be covered with strong metal?
The battery is integral to the case assembly, and should be replaced altogether.
このアンサーは役に立ちましたか?
If you're rich.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 527
