メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone 5 charge issues
Replaced battery in iPhone 5, worked fine for about a month, then dropped phone, got a small dent in bottom left corner and one in top right. Screen cracked. Started having charger issues, when battery drained it wouldn't charge, only displayed a red battery symbol.
Rebooted it with home+lock button pressed for 30s and after that it jumped to life after having charger plugged in for 2 minutes.
Replaced cracked display and cleaned out the lightning port from lint. Did a full reset in iTunes. Still having charger issues. Sometimes when left charging over night, battery percentage hasn't gone up. This problem has occured after dropping phone. What could be the issue? Lightning port?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
robertdanielsson, start off with replacing the battery and the lightning connector. If the phone still will not charge after that, you are having issues with the charging circuit (power management IC) on the logic board. That will be a very difficult repair, if even possible.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So it's one of these three?
I've also tried charging in different computers, different lightning cables, iPad and iPhone charger (genuine), won't help.
さんによる
コメントを追加
回答を追加する
robert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 153
