メインコンテンツにスキップ
Microsoft Surfaceのアップグレード版モデルです。Microsoft Surface Pro(1514)のラップトップ/タブレットは開口作業が非常に難しく、デバイスの破壊なしでは修理はできません。
54回答 すべてを表示
Surface Pro won't turn on but the home button still works.
My surface won't turn on.
What happens:
1.the charger's light is off
2.the screen is off
3.the home button vibrates when pressed
It isn't in warranty anymore but I can't afford to replace it and I do not have the right tools to fix it...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
最も参考になった回答
it might be stuck in standby mode or the screen might be bad. Try a full reset by holding the power button and the volume up for about 15 seconds and see if it will reset to the surface logo- if it does it should boot from there. This might be one of those surface stuck in standby glitches that can be fixed by a full power off with the above step.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I’m having The same problem please help
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes, me as well.
さんによる
コメントを追加
Tried the hard reboot with the volume up, and power button, but it did nothing. Are there any other ideas on how to fix this ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have had the same issue for 2 years with my Surface 2 purchased in 2013.
Symptoms:
  • when I press the power button, the screen does not start (stays black)
  • the windows button works (ie it vibrates when pressed)
  • the power cable’s light is on for approx. 10 min and then goes off
  • When I hard reboot, the windows button does not vibrate anymore
I managed to start it again by hard rebooting then pressing the power button many many times. At some point, it starts, and when it does, I keep it turned ON all the time (no sleep, no hibernate, no power off - see power options).
I don’t know how to fix it. I feel it is the battery because the time goes off after such restart. Battery should keep it but it does not, so that’s my clue.
Please help. Thanks in advance!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
elamzachariah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 29
今までの合計 3,672
