メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Can't call out or receive call after drop in water
Dear iFixit community, I have an iPhone 5 white 64 GB. Sadly, it had an accidentally bath in a lake. Not salt water. So it has dried up. It power up and down fine, WiFi works and so on. But for some reason, I can't call out or receive calls. I have done the following: 1. backup the device via iTunes 2. checked for updates and updated with the latest 8.3 iOS and the update about cell network provider (I think is the translation) 3. changed the SIM-card. 4. Factory reset. After that, I managed to do one call out and one incoming call. But then it died again. After these one-timer, the ability of making a call and receive a call stop working. All other function are working fine, like web-surfing, take mail via WiFi, get updates via WiFi.
So given that, any thoughts of what can be done? Can I maybe replace the SIM-card reader?
Kind regards
Leopold, Sweden
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This may not be a solution but from my understanding there is a resistor on the main board called Board_id, which is responsible for how the devices identifies itself (eg. Apple TV, Apple iPod, Apple iPhone Cellular, Apple iPad Wifi Only, etc) it may be that the water damage has effected this chip/resistor causing it to malfunction in a way.. not sure but would certainly assume it's board related.
Sorry I can't be more conclusive, feel free to correct me if I'm wrong on the above! it's a bit of a broken memory!
Will
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello Will! Thank you for your feedback. I have popped it open to check what can be done. As I suspected, every water-damage-indicator has been activated. See attached image. I have put the rear case in a silica bag while eating lunch. Will update on progress after that.
[image|576890]
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,650
