メインコンテンツにスキップ
Sony Xperia Zは2013年に発売されたAndroidベースのセルラーフォンです。Sony Xperiaの中では、5インチのHDディスプレイを持つ最も大きなモデルの一つです。モデル番号はC6603/C6602です。
98回答 すべてを表示
device it´s not charging after a little water test
Hi, my device it´s not charging, apart from that all it´s ok, i was just doing a water test...
in less than a 2 mins air bubbles appear in the sim port, i took it outside the water and it start to reboot with apparent sim problem then i pull off the sim, then i dry the phone with mi shirt, it restarted again and then it was working normally.
After that i put it on rice all night, but in the morning i wanted to charge it and afeter 5 seconds plugged the led turns off and appears like disconected, what can i do? thank u!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
I won't ask why you were doing a water test, no good thing can come out of that...
You may want to take the device apart and give it a clean with 99% Isopropyl alcohol and a fine tooth brush. I tend to soak in the solution then clean with a brush but you could typically have corrosion within the connectors causing the connection to fail intermittently.
Hopefully this will help, if not you might need to replace that part, although my knowledge of Sony Xperia phones is limited, not sure if this would be a solder job or not..
Hope that helps!
Will
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
rokerwhish さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 154
