メインコンテンツにスキップ
セガジェネシス(通称メガドライブ)は、現在までにセガが最も成功したビデオゲーム機です。
37回答 すべてを表示
Why can't any controller plugged in as the first controller press up?
So I can use up on all my controllers in the 2nd controller slot so I know the controllers are fine. But whatever controller is in the first slot doesn't allow me to press up. I'm guessing there's something wrong with the connectors so I'm just wondering if I should just replace the whole thing or if there's an individual pin I could fix.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
I am not an expert on controller ports but if it is not letting you do certain tasks with your controller, it could be dirty. Try cleaning it with Alcohol and Q-tips/ paper towels. I would also recommend using a nylon brush (a toothbrush can work in a pinch if it is clean). Finally, when you finish scrubbing it down, use compressed air to blow any remaining debris out.
If cleaning it this way doesn’t work, then a deeper cleaning involving more tools such as picks from the cleaning section on ifixit may help. You can use those to force whatever is in there, out. But do this as a second last resort.
Worst case scenario, you’ll have to order a replacement part and sell the broken one online for parts. That way you can still decrease ewaste while fixing the issue.
Hope this helps!
  • Jakes Restorations
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh Lowe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 228
