メインコンテンツにスキップ
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
20回答 すべてを表示
How do I fix a dead screen?
With no other indications the screen has stopped working completely, and it just showing black. Is it possible to replace the screen myself? If so, what part do I need to order and how do I open this guy to get in there and make that replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Kode, first make sure that the issues is your LCD. Connect an external monitor and see if it displays correctly. If it is your LCD that needs to be replaced, follow this video
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
screen was hit by toy now shows a rainbow what do i do i just ordered a new screen///
さんによる
Hi quireapril,
Click on the link 'this video' above in OT03's answer. It is a video that shows how to replace the screen in an Acer C720 Chromebook.
さんによる
Hey, I followed this because I had a dead screen too. It's still dark, what do I do?
さんによる
@Sean Davis you are not telling us what you did. I assume your computer is a Chromebook C720
さんによる
Hello. How do I fix a computer monitor that won't turn on? It was perfectly fine yesterday but then completely won't work the next day. Whenever I plug in the monitor, its power button usually lights up red but now it doesn't. Does this mean it has a power issue?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Kode さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 2,028
