メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
New Screen and keys not working
I replaced my screen on my iPhone 6. The keys Y and the ) key don't seem to work. When I press either of those keys I get the keys beside it. Any suggestions? - Tom
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I have the same problem but slightly different because the entire middle row doesnt work unless i type sideways... I just replaced my screen today too
さんによる
I have similar problem .but with mine the soft keys at the button little above the home key ,none is working unless I zoom it ...any help pls
さんによる
コメントを追加
6件の回答
最も参考になった回答
This is either bad screen, or (more likely) a teeny bit of some kind of plastic or something stuck on one of the pins of your digitizer connector--either on the board or the screen. Check for that. If not, then replace the screen to solve.
jessa
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Thanks. I would think more would be wrong if there is foreign material stuck on a connector. Everything works perfect EXCEPT those 2 keys. I appreciate the guidance. I'll tear it down today. - Tom
さんによる
Does this happen in portrait and landscape?
さんによる
That was an excellent question. The answer is no. Those keys work fine in landscape. Why is that?
さんによる
They are in a different position on the screen when in landscape. My guess is that you have a tiny dead spot on the screen. I'm guessing the 6 doesn't work either and that if you use an app that isn't optimized for the 6, it'll behave differently because the keyboard is rendered larger. As suggested, check and reseat the connectors. Just to save some money, I'd try an OS restore via iTunes if the reseat doesn't work (i could be a funky software problem after all). I'm betting that you got a bad screen though, so you'll probably end up having to replace it.
さんによる
No--debris that blocks a single pin on your connector will behave exactly as you describe. The problem is no signal through one line. It is either debris or a failure of that line within the screen.
さんによる
2件以上のコメントを表示
コメントを追加
fault comes from touch digitizer. you may have to replace it display as LCD and touchpad both come together as a module.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I took the Iphone apart disconnected the battery first, then the 4 connectors to the screen. I then reset the 4 connectors to the screen and finally the battery. The keyboard on the screen now works perfectly!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As others mentioned I would try a new screen first, but then also try cleaning out the digitizer connection with some canned air to make sure all the pins have good contact.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Had similar problem with one of the phones. I solved the problem by constantly pushing(massaging) screen. Worked well for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same thing happen to me. It is an original screen and there were a few letters not working. So annoying. Luckyly it was just a missconection of one of the cables. Took them out, blowed in both sides, pluged it back in and it works fine ! Thank you everybody:)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tombruce さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 28,691
