メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2623回答 すべてを表示
46" Samsung Television won't power on
I have a Samsung LN46A530P1FXZC television and for some reason it won't turn on. After moving (wasn't dropped) when plugging the power cord in, I can't seem to get any power to the set and it won't turn on. Is it shot? or is there a fix.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
最も参考になった回答
Lovjoy, of course you made sure it was properly plugged in and the plug has power. If so, you should (unplugged of course) open the TV up and check the power fuse. Use a multimeter to make sure that you having power to the PSU. Download the service manuals from here and see if you are up to working on it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Correct But this set has 3 fuses so make sure you check all three on the power board.
さんによる
コメントを追加
Join the class action law suit or if your blood pressure is low, try calling calling them ;-) They will give you the run around of your life. At the end they gave me two numbers to call. I checked and they were both to THE same damned people i was talking to.
https://topclassactions.com/lawsuit-sett...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Lovjoy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 3,207
