メインコンテンツにスキップ
Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
33回答 すべてを表示
Nook glowlight awake button broke
My nook glowlight dropped and opened up, I did not realize that the button under the outside case for the wake and navigation of the nook is gone. Now I can not navigate the various screens and can only use the on/off button on side of nook, so I can't switch books,screens,ect. This is just a plastic piece that snaps on but I don't know where to find one. Where could I get this fixed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hey, Cathy.
Unfortunately, I don't know where you would be able to get one of those little plastic buttons, perhaps you could find somewhere to get one 3d printed. Fortunately, that little plastic piece is just there to make it easier to press the small momentary switch that is the actual button. In a pinch, you can depress the button with a pen.
You can find the button by looking at the space where the missing plastic piece was. if you look inside the bottom hole (directly below the screw) you should see a little white dot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi,my book shows me only wallpepers,its not respond for turn off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cathy Wheeler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,299
