メインコンテンツにスキップ
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110回答 すべてを表示
Help figuring out what part should I be replacing
The USB data connection on my OnePlus One stopped working.
This means that no connection is even detected on any computer.
This is not a driver issue as the computer doesn't even notice anything has plugged in.
It's not a software/ROM issue because the same applies to fastboot mode and recovery mode - no data connection.
More facts:
1) When plugging to a computer USB port - the battery icon shows the charging (lightning) symbol for a half a second and disappears and it won't charge. The computer, of course, doesn't see a usb device plugged.
2) When connecting to an AC charger - it charges just fine.
3) I already tried replacing the dock connector and flat cable unit - did not solve the issue.
Any insight on this will be greatly appreciated!
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Have you tried to use a different usb cable for the computer? Your current cable may be damaged which could cause this problem. Have you tried plugging it in a different computer? The fact the ac charger works leads me to believe that the usb cable you have is faulty or possibly the usb ports on your computer. I would try a different usb cable first. I had to fix my usb cable a few weeks ago as I was having the same problem. Three out of four wires on my cable had to be resoldered to the micro usb connection. After fixing the cable I have no issues at all.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I tried different cables and different computers. It's not the cable. The cable works on a different OnePlus One phone.
さんによる
コメントを追加
回答を追加する
Itay Nachum さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 75
