floppy drive won't open
my floppy drive won't open.
この質問は役に立ちましたか?
Try to get your finger or something similar to put in the drive and push the disk down and back. Then try firmly pushing the eject button while keeping the disk gently pushed back. That usually lets them release and eject.
このアンサーは役に立ちましたか?
There is usually a small hole in the optical drive carrier. Use an extended paper clip and push it in the hole so that it hits the eject switch.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 557
1件のコメント
so how did you fix this problem?
ceasuri shop さんによる
