メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
16の回答 すべてを表示
no light, no network, no warmth
Hi All,
For 3 year my airport did work very well. Now it seems dead..
Tried to open it up. can not see how to.. anyone idea?
Resetting did not work, so i guess powersupply is broken??
Robert
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
選択されたソリューション
is it a (M9470LL/A, model A1084) or a MB321LL/A, model A1264
but to be honest - it might be a good idea to give this to somebody with a good knowledge of those devices - it could be very dangerous to tinker with those devices
この回答は役に立ちましたか?
スコア 2
コメント:
model A1088 :-)
Yes. i already ordered a new one....
さんによる
コメントを追加
I have same issue with my APX Model 1264. My research online showed that most likely problem is busted power supply. Mine is not totally dead, the light turns off and no more wifi network once the device heats up.
There is a forum regarding this issue in http://forum.hardmac.com/index.php?showt...
I gez there is a work around this by attaching a new power supply.
Good luck.
Glenn
この回答は役に立ちましたか?
スコア 1
コメントを追加
I recently opened my AE to re-rout the power supply. However, this ended up being unnecessary. As soon as I got it open I realized the lithe ribbon cable had just fallen out. I suggest you try plugging it back in before you re-wire the circuit.
この回答は役に立ちましたか?
スコア 0
コメントを追加
I solved the problem of my airport express lights that were not on. I had no power , no WiFi, no nothing. I took the advice of someone else on this or some other questions and answers. I pushed the plug into the back of it extremely hard. LIGHTS ON!!!
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert さん、ありがとうございました!
統計データを表示:
過去 24時間: 5
過去 7 日: 17
過去 30 日: 67
今までの合計 10,593
