メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A two-meter amateur radio produced by Kenwood. Identifiable by the model number at the lower left-hand corner of the radio's LCD display.
Memory problems, erases when radio is turned off.
My Kenwood tm-241a has a new battery and still doesn't keep the memory. I program the memory and it will work until I turn the radio off for more than 3 seconds then it erases the memory. I replaced the 2032 battery and still same problem. How can I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
This commonly happen to TM 241, replace the SPI and you are good to go, but when you don't know how to replace it.
Just find out the front panel replacement.
Hope this will help to resolve your problems.
73
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What is the "SPI" you said to replace???
さんによる
SPI is where your radio menu(setting) is saved, replacement of this part need advance skills. So when you don't have advance electronics skills the only way is just to find this radio front panel.
さんによる
コメントを追加
回答を追加する
mattfleming75 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 17
今までの合計 633
