Why is my bottom speaker muffled?
I dropped my phone a few days ago and now my bottom speaker is muffled and static. My top speaker is working great though.
If you dropped your phone and the bottom speaker no longer works, then chances are that you damaged it. Before considering a replacement however, you should check for debris in the speaker in case that might be the problem. You can view the troubleshooting guide for more information, HTC One (M8) Troubleshooting. If that isn't the problem then I would recommend taking apart the phone to see if the bottom speaker has been damaged.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 364
