My screen is black but the phone is on
My screen just gone black and i brought the special kit and took out the back and did a pressure on the top left side of the back and nothing
Mine was black and i was able to use it (even when it was black) then the battery drained and now every time i connect it it vibrates every few seconds ? Suggestions ?
このアンサーは役に立ちましたか?
Ok, so it was dropped on the floor, nothing happened , the following day, i had it on the back side, suddenly, the screen turned whit/grey, and then black screen after i turned it on/off
at first it was still working and i can hear the lock/unlock sounds and received calls like normal, battery died, tried to recharge it, started vibrating every few seconds, tried everything on Youtube ,,, no luck
このアンサーは役に立ちましたか?
first thought is a damaged or faulty LCD, what happend right before ?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 96
