2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
3322の回答 すべて表示
ghost typing and random selection of apps
Hi whats the fix for this, ive bought this phone recently so i dont know the full history of it but the phone hasnt had water damage, and ive replaced the screen twice and problem still happening. Is it a faulty chip in the logic board that controls the digitizer that i could replace?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
Hi,
1) Check whether surrounding components missing or corroded around BCM5976
2) Heat location of BCM5976 carefully : 400C* is enough and don't heat over 20Sec
3) if above two not works Change the BCM5976 with upper and below caps
この回答は役に立ちましたか?
スコア 0
コメントを追加
Thanks for your quick reply i think your right with the chip being damaged, the shield over the chip has being removed and i can see that there is a discolour around the chip, have you a link to a video that i could watch? is it hard to replace and what tools needed. Id like to try and fix this myself, be a nice achievement.
この回答は役に立ちましたか?
スコア 0
コメント:
currently i don't have apple 5 logic board to show how to replace it. you should have experience to replace BGA chips as it is not easy. don't give up and dry to fix it
* if you replace it you are one of best BGA re-worker
* if you failed you will learn a good lesson about BGA reworks and it may valuable than you phone
* if you fail today keep the logic board safely and someday you will be able to fix it, if i say simply practice make perfect
by the way why don't you make my answer as accepted? :-)
による
コメントを追加
Has anybody got a links to micro soldering on iphone 5? are repair shops that fix this. Can only find chips for sale on ebay but no videos to show if its possible for a DIY job.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bazmc さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 121
