メインコンテンツにスキップ
-EF Mount Lens -Aperture Range: f/3.5-36 -Optical Image Stabilization -Ultrasonic Autofocus Motor -Internal Focusing System -Manual Focus Override -Constant Minimum Focus Distance: 20" -72mm Filter Thread Diameter
3回答 すべてを表示
Canon 28-135 f/4.0 IS USM Lens resist on turning
Hey guys
i totally no idea why does my lens resist on twisting whenever i zoom in or zoom out, i does require a certain amount of force just to twist the barrel of the lens.
how to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I have the same problem and it has gotten worse to the point that the lens is almost unusable
さんによる
コメントを追加
4件の回答
ベストアンサー
Hello Jan!
if the barrel is broken, you will need to replace it and additionally buy the CANON EF 28-135MM F 3.5-5.6 IS BASE ZOOMING GUIDE by $6 USD
http://www.procamerarepair.com/search.as...
i EXPECT can be usefully my answer.
good luck!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
The same thing happened to my lens and I tried to zoom in and zoom out forcefully and suddenly it snapped and a ring broke in my lens so don't try to apply force. I watched this video on YouTube to fix my lens but I seriously advise you to get it fixed if you don't want to try to fix it by yourself still I am copying the link to the video. Hope this helps.
https://youtu.be/PMUXqfTEXsA
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
my lens is stuck at 135, i mean it believes that is at 135 even though i am at 28, anyone knows something about that?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It could be that the lens threads are out of position with a slightly bent lens.
This has helped me getting it fixed, maybe that also helps others
https://www.youtube.com/watch?v=_4K1Ge5C...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jan Buencamino さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 29
今までの合計 4,108
