メインコンテンツにスキップ
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
409回答 すべてを表示
3DS won't stay stay on - makes a popping sound
Hello,
Recently I changed my 3ds LCD screen.
But once I tried to turn it on, it made a popping sounds and turn itself off after a few secounds.
I read about lossen ribbons and stuff, so I tried to disconnect everything and turn the 3DS on just to see if the motherboard can light up.
The blue light turns on for a few secounds before shuts off.
Could it be a blown fuse? I saw once that with blowen fuse the nintendo won't turn on at all..
What could be the problem? I discconected EVERYTHING, even the mic, and still it won't stay on!
Thanks.
- Theres no SD card inside.
- Theres no game inside.
- tried putting the motherbord inside a fully functationing 3DS XL.
- It charges.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
When it shuts off does one of the screens flicker for a split second? If the bottom screen flickers then there may be an issue with the top lcd. The 3d flex cable is usually the culprit. The ribbon may have a slight tear that is preventing the top lcd to power up which results in the blue light shutting off. To replace it requires a complete tear down of your system.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No flicker when I turn it on.
さんによる
コメントを追加
It absolutely will not power on if any of the ribbons are ripped or disconnected. Try reconnecting everything and look if the cables are ripped.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ChubbyKai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,150
