spilled beer on key board
Spilled beer on right side of Macpro 2.53 ghz unibody mid 2009 model.
Return key is now sticky.
Removed battery, turned upside down, put in dry place.
Wondering how to clean under key board.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
and wash it off then dry it with a Non-conductive, non-corrosive, non-residue electrical contact cleaner, 99% Alcohol and pack in a desiccant for at least 72hrs.
You should check the logic board for damage also, corrosion can build up over time. What should I do after I spill liquid on my device?
If this answer is acceptable please return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,896
