メインコンテンツにスキップ
Repair information for PowerBook G3 laptops from Apple.
83回答 すべてを表示
I installed OS 10.4.11, now my DVD drive won't work?
Want to install OS 9.2, but now my Pismo won't work with any DVD or combo drive I put in. System Profiler sees the drive, but the PB won't run the inserted disk. The DVD-ROM worked when I installed OS 10.4, seems to have stopped after that.
I think it may be that I did not install OS 9 drivers, starting over, will let you know. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Was the 10.4 a full retail version or from another machine? It can just be a coincidence that your optical drive died at that moment, or it can be a driver issue. Please provide more details on the DVD.
さんによる
Did you install the OS9 drivers when you installed 10.4?
さんによる
Tried re-installing 10.4.6, then used the combo update to 10.4.11. I am at a loss. It seems the DVD drive will read DVDs, but not CDs? Says this computer does not recognize this disk, or something. Hence, I cannot install OS 9.2 from the CD. Could it be the order I have done this successfuly before, and can't figure what I did this time so it doesn't work on this Pismo.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi, When I had a problem after installing 10.4.11 Apple had me reinstall the 10.4.11 combo updater. Cured the problem--don't know if it will cure yours but worth a try. (no cost) I am including a link to the updater for you. Ralph.
http://support.apple.com/kb/DL170
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
さんによる
Hi, The best I can do for you now is to provide the link for the Apple guide on installing OS 9. Ralph
http://manuals.info.apple.com/en_US/MACO...
さんによる
コメントを追加
回答を追加する
hermanski3 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,125
