メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
プラスチックに関する情報の保管場所。黄ばみ除去、修理、改造などの修復技術を含みます。
How do you take off paint scratches from a plastic surface?
I just wanted to ask how I would take off some white wall scratches off of my plastic vacuum ?
is there any type of liquid you can find at home that takes away that stuff?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
First you'll want to try one of the Citrus oil cleaners like: Goo Gone. Just test it out some where it won't show first. They do a good job on label adhesives as well. I would then try using a polishing powder like: Bon Ami with a damp cloth as it won't scratch. After either you do want to put on a protectant like: Armor All.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
thanks so much for the help I really appreciate it :)
さんによる
コメントを追加
There are a variety of plastic cleaners, polishes, and compounds that work well for this. I have found Novus Plastic Polish Kit to work wonders; Meguiars has variety of products based on color and type of plastics; Mothers also has a polish for scratches.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
First step is to remove the wall paint without Scratching the plastic surface. Dry wall paint gets soft with - water! No rocket science needed. If possible submerge it into water with a dash of dish cleaner for some minutes. Than take a wooden spatula or fingernails to scrub it from the surface. Any scratches you can polish with toothpaste or grease based polish like mentionned before.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 109
今までの合計 9,279
