メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
iMac Not Booting - Fan spins then stops - LED 2 blinks
Hello, my iMac appears to be having hardware issues. I thought it was a power supply issue, so I bought one from this website, but I'm getting the same issue. LED 1 lights up and stays lit, LED 2 blinks 1 time, LED 3 and 4 both do not light at all. Also, when LED 2 blinks both fans spin for about 3 seconds, then stop. This process never stops as long as the power cord is plugged in to the wall. Ive tried all the typical fixes, reseated RAM, reset SMC, pram, and replaced the power supply. I'm thinking it's the logic board, but I can't find anything online with these same symptoms. Any input would be much appreciated. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
3 件のコメント
Did what i wrote help you?
さんによる
What ended up being the fault, mine does this problem also
さんによる
I have a service check and they ask for 700$ to replace the motherboard. I throw away
さんによる
コメントを追加
3件の回答
最も参考になった回答
The first LED means your power supply is fine.
-it should always be on when the power is plug in.
The second LED means your logicboard is fine.
-it should aways be on when your computer is on.
The third LED means your video card is one.
If your second LED doesnt stay on that means you have a logicboard issue.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
What if the issue happened after reinstalling ram? It worked perfectly fine before
さんによる
コメントを追加
Just found the fault. Remove your ram vacuum and clean the slots, clean ram and fit 1 ram at a time, I removed the ram I upgraded 2 years ago now it boots up.
from my research if you still have issues it will be a logic board but check your ram first
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I had the same problem: upon opening the iMac, found LED #2 flashing about 1 Hz. Replacing the upgraded RAM with the apple original RAM allowed machine to boot. (Wish I had checked this BEFORE spending an hour removing the display and the adhesive tapes!)
さんによる
Fixed it for me thank you
I assumed it would beep if there was a ram issue so I didn’t think it could be the ram and I was about to put this one aside for spare parts!
さんによる
コメントを追加
I had same issue and same led pattern. Like a dummy, I had LCD thermal sensor cable plugged into the unused port to the left instead of the port next to the Display data cable/LCD cable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kelaure さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 2,470
