charger is stuck in the tablet
so my charger got stuck in the tablet and I tried to pull it out and now only the metal part is in the tablet and because of that I can't charge it .
please help
Hey there!
A couple simple options that can probably get that out would probably be some hot glue (if you're careful) in the slot to stick to the metal piece that's stuck and pull it out when it cools.
Otherwise if you're good with fine pointed tweezers or possibly a safety pin to push on the latch that locks the connector into the tablet, you may be able to get it out with patience
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 347
