Why wont the rear case come loose?
I cant get the rear case to come apart using the plastic opening tools. How do I get this off?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sometimes the rear case can be very tight. Make sure you have removed the two screws described in this guide.. Once you have those removed try using more than one plastic opening tool to pry the rear case off. If this is the first time taking your tablet apart it may be very tight from manufacturing.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
