Internet icon does not work
when I downloaded firefox browser the internet icon did not work. Kindly would you assist to rectify this problem. When I click on the internet icon it gives this message "Internet has stopped" Thanks.
For Nokia XL User:
go to Setting , Phone , Apps , After Select Manage Apps , Right side of Corner Select All folder , there Icon Showing internet Option, Select and do the following below
Force Stop
Turn Off
Clear Data
Clear Cache
Clear Defaults after turn on and open Internet browser again
このアンサーは役に立ちましたか?
It worked perfectly. Thank you so much.
Thanks a lot. It's working perfectly. Saju Joseph.
Thanks a lot , u helped me to fix it .....thanks ...
My phone's internet is now running well. Big help, thanks a lot!
You helped me a lot!!!!! thank you !!!!! love you!!!
try this
first disconnect your WiFi or internet connection
go to the browser setting go to clear private data icon
then clear all data
shutdown and restart
このアンサーは役に立ちましたか?
did not help
it's not helpful.
but all my data will be cleaned,is there another solution??
thank you very much. It was of great help
yes i also have this problem right now,but i couln't solve it til now,pls help
このアンサーは役に立ちましたか?
hi.
my nokia xl phone some file are auto install, & the file name of auto install com.google backup is not stop. i am many time reomve this file but this file auto instal in my phone please send the solution on this problem
Ajay
このアンサーは役に立ちましたか?
My Nokia RM 980 I was Selected SIM1 For 3 G Use But Now My Sim1 Slot is not working so i need to use it for SIM2 so if i going to choose for SIM 2 it is not working plz help me
A web browser acts as an interface between a user and internet. It used for several purposes like accessing websites, searching and retrieving data, etc. We are providing Online browser support in order to serve quick solutions when a fault is occurred while using them.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 13,148
1件のコメント
my phones ok but the I cannot turn off the mobile data
when turn off the data and lockscreen it well on automatically so pls help me in this situation
Mahran Al Balushi さんによる
