The Canon Vixia HF20 is a compact, ultra lightweight high-definition camcorder.
Ke'Andra @keandra
評価: 1
投稿日: 2015年4月28日
If the screws are stripped, what can I do to still fix the problem?
この質問は役に立ちましたか?
Taylor Morris @taylormorris
評価: 225
7
One way you can fix the problem if the screws are stripped, is to use a very fine screwdriver, and while trying to unscrew the screw apply enough pressure so that while you are taking it out you do so not to strip it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 88
