メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
締切られた回答
iPhone 5c: Replaced lightning port and battery but still won't charge?!
My daughter did a number on her iPhone 5c and I replaced the lightning port assembly, the loudspeaker assembly and the battery. Now the battery won't charge. When I plug the cable in I get the tone and the charging icon but the battery level never goes up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Did you try to see if it makes a difference if you re-install the old battery?
さんによる
コメントを追加
2件の回答
This might be a dumb question, but have you tried a different cable?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried 3 different cables, two different AC adapters and plugging it into the wall and the computer (3 different USB ports). No dice.
さんによる
コメントを追加
What exactly happened to the iPhone while in your daughter's possession? You may possibly be experiencing a failure in the logic board "power management ic", assuming your replacement battery-cable-connector wasn't somehow defective. It is generally an uncommon occurrence (and an expensive fix, unfortunately), but some experts think cheap, "fake" Apple chargers/cables are to blame for the bulk of these failures. Please check out this article to see if it sounds like your problem: https://www.mendmyi.com/blog/2014/06/has...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 238
