メインコンテンツにスキップ
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137回答 すべてを表示
締切られた回答
Cannot fully open the laptop.
Hello everyone,
I have a HP DV7-6b30eb which is seriously overheating and i suspect the thermal paste needs replacing. The problem is i get stuck when opening the machine. I have removed all the screws on the bottom half of the machine and it looks like i have to remove the palm rest by lifting it up. It lifts up everywhere except at 2 points. In the zone of the R,4 and 5 keys and between the O,9 and 0. When i lift up the palm rest to the point where there is tension on these points i can see inside a bit and it looks like the points where it wont lift are see through plastic of some kind.I have tried moving it in every possible direction in the hope it would un-click, but no joy. I cant find a disassembly layout specific to my laptop on-line.
Please help! Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Solved it. Being a dumbass.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Care to add how you solved it for others?
さんによる
コメントを追加
As with a lot of laptops there is a hole on the bottom of the laptop where you have to push a screwdriver, or something alike, to push the keyboard out of its housing. Then you can remove 2 screws on the points i described having trouble with and then everything is a breeze from there.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 189
