How can I get my laptop to turn on?
When I press the power button, the laptop will not report any signs of turning on. The charger is plugged into the laptop. What can I do to get it to turn on?
Your laptop’s battery may be faulty and unable to retain a charge. You’ll need to replace the battery if this is the case. The problem may also result from having a faulty battery adapter. If this is the case you will need to buy a new charger. You can also check out this troubleshooting guide to learn more.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 746
