メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
iPhone 4 Back Panel Mount Frame Missing
I recently bought a iPhone 4 back panel replacement and I got it today, but the bad news is that the back of the back cover is flat, nothing there, no mounting frame like: http://i28.tinypic.com/15o78lu.jpg
Can I remove the frame from my old iPhone 4 back cover and install it on the new on? Is it glued on?
This is really urgent, Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
最も参考になった回答
I removed the back plate then removed all the broken glass. Used paint thinner then denatured alcohol to clean up the rear frame, heat gun might work too. Then used a spray on interior adhesive on the glass protecting the camera/flash area
Update
used a small screwdriver, exacto knife blade as it has to be perfectly clean. Broke the first one as there was a small piece of glass I missed and looked again with a magnifier
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Assuming Apple used the same design philosophy on the iPhone 4 as on the iPad, iPhone 3GS, and iPhone 3G there is a double sided adhesive strip that connects the glass to the framing. If you follow Step 15-18 of this guide, you should be able to separate the two pieces.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'd definitely like to know this too. There seems to be a $150 price differential between the plain glass sheets and the sheet affixed to the plate assembly. The former also seems not to have lenses to cover the camera and flash.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I need to know this answer too, how would i replace the glasS? because i bought the "Glass" so how do i remove the glass from my broken iphone because its cracked
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've read elsewhere that the glass adheres to the rear frame with very strong double sided tape. Using a heat gun to soften the adhesive before removing the glass is supposed to help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey Guys i found something interesting look at this it looks like its the panel/frame that that the glass mounts in. Could someone help mo out would this work to mount the glass in with some adhesive then put in the phone?
http://www.globaldirectparts.com/Product...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
webtalkable さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9,300
