Why isn't my break light working?
Why won't my brake light turn on when I press on the brakes?
You may have a burnt out light bulb. You may also want to inspect your fuses to see if the fuse associated with the brake lights is blown. If it's neither of the above then it may be a problem with the wiring for the break light or the socket the brake light fits into.
このアンサーは役に立ちましたか?
Do you have less then 3 years / 36,000 miles, if yes then take it to the dealer.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 445
