Why does my motor sound weird?
Whenever I try to fly my gyrocopter it makes really weird noises and I don't know whats wrong with it.
If you are hearing strange noises from your helicopter, there could be problems with your drive gears. If you are not having enough power to take off or you can only get one of your rotors to spin, these are also signs that your drive gears are the problem. You can find more information about this and other common problems on the troubleshooting page.
このアンサーは役に立ちましたか?
Listen to the gyrocopter carefully to know where the sound come from.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 184
Can you give a better description of the noises?
mayer さんによる
Due to the new page design I cannot edit your device. Maybe you can. Remove the dash after Gyro to see if the Wiki students are building will come up. (Probably your group).
mayer さんによる
