メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
Repair and disassembly guides for the AEG Trockner T56840L Dryer.
1の回答 すべてを表示
dryer not turn on like no electrice
dryer not turn on like no electrice, the cable in connected
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
選択されたソリューション
Breaker Box
First check your electrical breaker box to see if its getting juice.
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
この回答は役に立ちましたか?
スコア 2
コメント:
I have a AEG drying machine model t56840 when turning on the hiting is weak . what is the problem
さんによる
The machine running , but the time of running is to short & the heater is hot but the control board comand to stop the drom & heater, so the heating is too low. Is the problem in timing in the electonic board?
さんによる
Can I have the service manual for electric wiring & electronic board?
さんによる
@mehrabyazdanian possibly @oldturkey03 would know where to find that.
さんによる
Dear Mayer
Thank you very much for your efforts,
Yours sincerely Mehrab
さんによる
コメントを追加
回答を追加する
avi cafri さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 74
今までの合計 6,827
