メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
4470の回答 すべて表示
Sony Bravia 32 inch LCD KLV-32EX400 display panel cost in India
Hi,
Can any one help me fixing vertical, Horizontal lines and ghost image(double image) on my Sony bravia 32 inch LCD TV. Is it possible to repair it instead of replacing the panel. The panel in India costs around 12500INR. Please help me resolving this issue.
Thanks in advance.
Regards,
Naga Suman
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 17
コメント:
Naga Suman, post an image of what your screen looks like. this could be as simple as bad capacitors on the power board, or a bad T-con board right up to as bad as a TAB failure on your panel.
による
My Sony 32bx350 lcd tv's picture jumpy.....flickering...the servicemen told me its panel has to change and its cost abt 12000.....I think the panel has no problem. May be some little issue in main board or t-con board. Anybody can answer what will be the problem.
による
I too face the same issue all of sudden while watching suddenly double images came, my 32 EX400 same model TV has the double image issue which we bought in 2010. When the service guy visited he said display gone we need to change the display and it costs around 13K with one year warranty. Don't know why such a big brand Sony has such type of issues without any repairing just replacing...
Regards,
Gauri
My complaint#37092766 from PUNE INDIA
による
In normal models sony uses samsung panel or lg panel. The failure rate of samsung panels are very high, That is the problem. The problem is with its internal crystal leakage or with bonding. In some cases it is possible to repair, but it required bonding machines and same CAF
による
In my case the upper layer of LCD seems to be whitish and there is wrinkles all around the panel also.on the bottom portion a white patches is visible and it is also hiding the picture a lot. I mean if I say the LCD has two layers the inner most layer is showing the picture correct and the upper layer is becoming faulty. How do I rectify this problem.should I have to replace the whole panel or the upper layer can be changed. Vijay,Ranchi
による
表示する 12 他のコメントを
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
6回答
選択されたソリューション
Naga Suman double images, ghost images and horizontal lines are usually caused be failed gate drivers and/or gate tab bond failure. For a repair you will need to find the right schematic for the LCD panel. It will not be in the TV's service manual. To start looking for that you will need to get all the data from the label on the back of your panel. Since this information is not readily available it will be very difficult to repair it. That is the reason for replacements of the panel. Something that looks similar to this
is caused by a faulty gate driver. It has nothing do it with the "plastic shield" on the LCD
この回答は役に立ちましたか?
スコア 6
コメント:
Sony bravia lcd 32 inch tv is in repair condition....there is a problem in display...so how much cost for repairing that
による
The same display problem is in my sony ex300 lcd tv.
による
The same display panel problem is in my Sony 48 inch TV .So how much cost for repairing
による
I purchased Sony Bravia TV 32 inch in 2014. There was 5 times red blinking. Informed by Service Centre that Display panel which is costing Rs12 k need to replace. Further shocking am informed Display panel is not available with them or centre abroad. Very shocking for me. Can anybody advise me availability of display panel outside Sony
による
Repairing...is waste....myself cheated by Sulekha .com.s technician.. Thirunavkarsu taken ₹1500/= in the name of spares...on goodwill & human faith gave without any receipts... it's already one month over not replying or picking up my repeated calls
による
表示する 3 他のコメントを
コメントを追加
You have to replace the plastic shield on the LCD panel.the LCD itself is good.
この回答は役に立ちましたか?
スコア 4
コメント:
Sony bravia 32 lcd model KVL 32 BX 35A PANEL COST ?HOW CAN I GET ?
による
Sony Bravia KLV-32R512C screen seems cracked. Can anyone tell me to fix this? If it needs replacement, then where it will be available? What is the cost for new display panel?
による
@kistnen please tell me how to remove plastic shield?
による
@kistnen
this is not anything related to any "plastic shield"! You answer is wrong and misleading.
による
I am also facing the same issue, all of the sudden while watching double images came. My SONY BRAVIA KLV -32EX300 model TV has the double image issue which we bought in 2013. The service guy said display (TV PANEL) has gone, we need to replace the display and it costs around 10K. Don't know why such a big brand Sony has such type of issues in just 5 years...
による
表示する 2 他のコメントを
コメントを追加
It sounds like the connection from the LCD screen to the main board isn't quite right. Unplug the device from power. Watch this video until about 2:10, which should help you remove the back cover from the television. Then, check the main board-screen connection and make sure it is secure. Also, check for any bent pins on the connector itself.
この回答は役に立ちましたか?
スコア 2
コメント:
my soni braviya 32 inc Lcd panels is white
how much price in Replec ment cost??
による
コメントを追加
This is the problem lcd tv it doesn't not fix at all. Only dancing and doubleing images are shown and also horizontal lines are running on display screen. Please any one have book of lcd penal repairing guide book help me about this topic. How to short out these problems?
この回答は役に立ちましたか?
スコア 1
コメントを追加
Can anyone suggest what is the issue. See left bottom side for a blurry white patch coming on screen.
この回答は役に立ちましたか?
スコア 0
コメントを追加
I required mother board of of klv 40 nx5000
この回答は役に立ちましたか?
スコア 0
コメント:
Can anyone help me in knowing the repair price for fixing lcd screen scrahes issue? I use 32BX300 LCD TV purchased in 2010. TV is in working condition but could notice multi colour scratches during blank screen or while changing the channel.Appreciate any help!
による
コメントを追加
回答を追加する
Naga Suman さん、ありがとうございました!
統計データを表示:
過去 24時間: 78
過去 7 日: 577
過去 30 日: 2,629
今までの合計 108,410
