How do I fix the uneven sound in my headphones?
When I listen to my headphones, I can sometime only hear the bass out of one ear piece and the vocals out of another. How do I fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This can be due to a problem in the wiring or the auxiliary plug. To test either one, run your fingers along the wire and see if the problem can be temporarily fixed. If it can be fixed, the problem is with the wire and you will have to fix the wiring. For help with fixing the wiring, read the Skullcandy UPROCK Earpiece Wiring Replacement Guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 17,571
