My WFW70HE was started with the water shut off
now it sounds as if pump is running and the door can not be unlocked and none of the other buttons including power will work
Push "Wash Temp", "Spin", "Soil" three times in a row, then the panel should come to life. Then you have to wait 10 minutes for the drain cycle to run and the machine will turn itself off, which is part of the reset process. Then turn the machine back on and operate as normal.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 151
