Firewire Port Not working
All of sudden my g5 front Firewire port is not working. I have no problem with the front USB port. Please help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I've had this happen on my G5 Mac Pro dual 2.0 GHz. I could not get the front firewire or USB ports to operate. I added a 5 port USB PCI card to give me more ports. A couple of months later, and after some system updates, I forgot that the ports were not working and plugged a flash drive in. The port worked fine. I then tested the firewire port and it was working. I'm running 10.5.8 and I can't tell you why they didn't work for a while. So do the software updates as I don't think it's a hardware problem. The keyboard USB probably doesn't get enough power for the flash drive. Also try the flash drive in one of the back USB ports to see if it is working at all.
このアンサーは役に立ちましたか?
+ Ralph
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,530
3 件のコメント
I take it that this is on a MacPro?
mayer さんによる
I think it's a PowerMac G5 (He mentioned g5, but I didn't think the G5 iMacs had front firewire ports).
Sterling Hirsh さんによる
My Mac G5 does have 1 firewire and 1 USB port in the front and, as earlier indicated, the firwire (front) is not working. Here's a new development, the flashdrive is no longer being recognized from the keyboard USB port nor from the front USB port of the G5. Help!
gene さんによる
