Xbox One no wifi connection wireless or wired -Please Help!
While playing on my machine I lost internet connection. I did the usual checks and there was no problem with any other equipment in the house connecting. I have rebooted and after that reset the system and nothing has worked. As I have reset the system I am now locked out of the machine altogether as the machine needs to connect to the internet during initial set up. I now get a message saying there is a hardware failure.
I have repaired DS’s PS3’s etc. and so quite willing to open her up but looking for some guidance.
Is this likely to be a WIFI board failure? From the teardown here I see the WIFI board is connected to the RF board, is it that that may have failed? If it could be either is there a test I can do? Finally I have check out eBay and none of these parts are available there so any ideas where they can be purchased? Any and all help gratefully received.
Many thanks Dan
1件のコメント
Hello I have a concern on my Xbox one about the wifi...I can not connect to the internet only connected via router, none of the list of wifis pop up. And when I click the tab to check my connection it says i'm all good and connected to the internet but i'm not that's the issue. i have tried hard resetting, factory resetting and nothing works still. Is there any way this is the issue with the wifi card inside the console? or should i follow the HDMI tip? i'm not sure what to do on this so if someone could help me that would be very much appreciated :(
Joel さんによる
