メインコンテンツにスキップ
A 15.6’’ laptop, part of Gateway’s NE series released in June of 2013. Contains a 1.4 GHz AMD E1-2500 dual-core processor, a 500 GB HDD, 4 GB of DDR3 SDRAM, and comes preinstalled with the Windows NT operating system Windows 8.
5回答 すべてを表示
Why isn’t my touchpad working?
When I try to touch or click the touchpad it doesn’t respond, which is really frustrating because now I can’t navigate around my computer.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi Aaron,
You may have just accidentally disabled the touchpad. To check if this is the case, look for a button located above the F7-F12 keys. It’ll look like a square with a hand and a plus sign, if the red light is on, then it’s disabled. To fix this, simply press it again to turn it off. After that your touchpad should be working again.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks a lot Stephen! I had the same problem and now it's solved. Actually i posted the same question yesterday but remains unanswered. I didn't have the chance to check on he posted questions/answers before I posted my question. Thanks a lot again! You made my day.
さんによる
コメントを追加
回答を追加する
Aaron Hocher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 126
