Why wont my tablet turn on?
The tablet will not respond or show any signs of turning on.
Faulty Power Adapter
Check to make sure the power adapter is plugged into the wall completely. If it is, make sure the light on the adapter is on. If the adapter light is not on but it is plugged in, this likely indicates that the adapter is faulty. Consider purchasing a new power adapter.
Faulty Battery
If the adapter is still working, check to make sure the charger is plugged into the tablet completely. If the tablet will turn on with the adapter plugged in but not while unplugged, regardless of charging time, the battery is faulty. Follow this guide to replace the battery.
このアンサーは役に立ちましたか?
Faulty Battery
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 229
