Why does my camera turn off suddenly?
While using my camera, it turns off without my doing.
Hello,
This may be a problem with the temperature of the device. If you are in a cold environment or a fairly hot environment this may be causing the problem. To fix this, warm or cool your device down by bringing it to a more appropriate environment, such as a room or warmer or colder area (depending on the situation).
This could also be your battery running out of charge. If this is the case, plug the battery into the charger.
Device page for the Sony Cyber-Shot DSC-T5:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 119
